cdavis Posted December 27, 2007 Share Posted December 27, 2007 When creating a plant in Landmark if I type in the latin name when creating it the plant turns into a dot. If I leave out the latin name of the definition when creating and add it later the plant works normally. I have installed SP2 for XP. Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted December 31, 2007 Vectorworks, Inc Employee Share Posted December 31, 2007 Hi Just had a go at reproducing this and my plants seem to work fine. Can you provide a little more detail on how you are creating the plants? (i.e. Are using the menu item on the Landmark menu and choosing one of the default symbols, or are you first drawing your symbol and then creating your plant?) What other settings do you have for the plant? Do you have a cross or dot selected for the centre of the plant? If it's a dot, I've had problems before 2008 where the dot obliterated the whole plant, regardless of the size I set for it... Let me know. Tamsin Quote Link to comment
Jonathan Pickup Posted January 1, 2008 Share Posted January 1, 2008 I?m not having this trouble either. My plants are working fine Quote Link to comment
