Buckaroo Posted May 16, 2007 Share Posted May 16, 2007 (edited) I swear, this program is a pain. I'm just trying to connect the corner of 2 objects. I have created 2 extrusions. One a long board and the other a odd shaped board. Both have corners, but I can not get the corners to connect. FormZ was so much easier. Edited May 16, 2007 by Buckaroo Quote Link to comment
Gytis Posted May 16, 2007 Share Posted May 16, 2007 Before going nuts with judgement, remember that VW is a different program than FormZ, and it takes time and effort going through the many available resources to learn how to use it efficiently. In this particular case, have you looked at the options available via the Constraints Palette? Ones like Snap to Object? Quote Link to comment
propstuff at MJLA Posted May 17, 2007 Share Posted May 17, 2007 Both have corners, but I can not get the corners to connect. What do you mean by "connect the corners"? Quote Link to comment
Buckaroo Posted August 26, 2012 Author Share Posted August 26, 2012 Gads, I can't believe I had the same problem 5 years ago. I upgraded to Vectorworks 2012 Fundamentals. The problem apparently went away or I finally figured it out 5 years ago. Recently I created a 3d model and within the last couple days I can no longer snap onto a 3d object. The example shows what I'm talking about Quote Link to comment
michaelk Posted August 26, 2012 Share Posted August 26, 2012 hmmm I'm able to snap to the extrudes and the lines. Have you checked your smart cursor settings? Quote Link to comment
Buckaroo Posted August 27, 2012 Author Share Posted August 27, 2012 I don't know if this screenshot will help describe my problem. It didn't do this until just recently. [img:center]http://www.michael-r-taylor.com/screenshot.jpg[/img] Quote Link to comment
Buckaroo Posted August 27, 2012 Author Share Posted August 27, 2012 Until this problem came up I was able to determine the angle of a line by selecting it. Now I can not. [img:center]http://www.michael-r-taylor.com/screenshot2.jpg[/img] Quote Link to comment
Kevin McAllister Posted August 27, 2012 Share Posted August 27, 2012 Buckaroo, What are your computer specs? You should add a signature to your profile ( under my stuff above ). I've had some unreliability with snaps after upgrading to OSX Mountain Lion on a Mac. Kevin Quote Link to comment
Buckaroo Posted August 27, 2012 Author Share Posted August 27, 2012 (edited) Sorry about that. VectorWorks Fundamentals 2012 SP4 Mac OSX 10.7.4 iMac 27" 2.8 Ghz Intel Core i7 Edited August 27, 2012 by Buckaroo Quote Link to comment
