propstuff at MJLA
38 -
Reputation
0 NeutralRecent Profile Visitors
How to set a fixed ratio for fence slope in the DTM?
propstuff at MJLA replied to Art V's topic in Site Design
Re getting the angle of a slope from its Run and Rise (X&Y); draw a line with the appropriate X&Y distances and then select Polar Coordinates in the Object Info Pallette (OIP) Read the angle and length (diagonal) of the line from the OIP Re constraining the slope; You can't with the Fence from Pad command. Max slope will be supposedly the Maximum slope not the nominated slope. It also didn't work in the test file I just made. Regardless of the slope distance, it made a varying slope which was steeper than the 18.46? I entered in some places. -
Where a moulding turns a corner (say in plan) and springs at an angle or arc in elevation, the second moulding does not have the same profile if the 2 pieces are to meet correctly. The profile needs to be "developed" to find the new profile. (A bit like finding developments of solids and "true shapes") Sketcher; the Shear Tool might do it, but I haven't tried it. N.
I've had this in the past: very frustrating. Deleting the site model and regenerating it with exactly the same data and modifiers has worked for me.
A Hidden Line drg will not display Textures. Some people "annotate" hidden line viewports with polygons that have a hatch (eg shingle) applied to them. another option; If you create a Shingle texture from linework on a white background, you could apply that where you want, apply a white fill to everything else, and render in the new Open GL with lines mode. (you might have to turn the Ambient light up to make the white display as white not grey) there will be other suggestions I'm sure N.
time is dependent on the actual contents of the drg as much as the size. "Not Responding" doesn't necessarily mean it's hung. How long have you waited for it to render?
Hmmmm, interesting. So, to get it to export an HDRI image that would function the way a "normal" HDRI does, what settings would you suggest. cheers, N.
It's pretty easy. Scan your sketch Open a new Layer in your file at the same scale as the sketch you made. File>Import Image. The image should be close to the right size. Pick an object you know the size of and measure it. Select the image. Choose Modify>Scale Object In the Scale Factor field put 'the size the object should be' / 'the size you measured it' The scan should then be the right size to trace. You'll probably have to pick a long edge to rotate the scan to vertical-horizontal. Note: for both the Scale and Rotate operations,; the larger the feature you use, the more accurate the process will be. N.
Come to think of it, converting to a 3D poly might make a Bazillion verticies if your path is curved. Converting to NURBS should produce a shape that can be edited in 3D fairly easily. N.
Get rid of "None" and "Main" Classes
propstuff at MJLA replied to Christiaan's question in Wishlist - Feature and Content Requests
Perhaps even "default" ;-) I don't know how many times I've had to explain that Class 'None" does not mean that there is no class. Then again, if Islandmon can turn a Mistake into Spontaneous Serendipity, perhaps the "None" class should be named "Everything" :-) -
Well I'm not expert in this, but I had exactly the same thing happen and it was 'fixed' after I set the layer height to 0. For a 2 storey building I'm not sure what would happen. I agree it seems counter-intuitive with the whole layer height thing, but maybe we're both doing it wrong. ;-) N.
I think you'll find it's because roofs have a bearing height. try setting either the layer height or the bearing height to your measurement, but not both. HTH, N
where are my section markers?
propstuff at MJLA replied to propstuff at MJLA's topic in General Discussion
Well, As you ask,... No. I suppose I could have RTFM, but thats a procedure that I completely missed. thanks Peter. -
Hi Peter, I tried that, and a restart; still nothing. I also tried ungrouping put the bits into the none class, but that broke the arrows. :-( -
I have a dtm on a Design Layer. It has Section Viewport Markers on the same layer. The markers are in the Section Style Class and the class is visible. I made a viewport which includes the dtm Layer and the Section Style class set to visible. The sheet layer itself has the appropriate layer and class visible, and options set to show snap others. The Section markers are not showing in the viewport. What's the story here do you think??? N.
Right click the object and select activate layer/class
