willofmaine Posted March 16, 2007 Share Posted March 16, 2007 What's the best way to create a concrete cap for a stone wall that's both curved and the top of which slopes up and down? After finally getting an extrude-along-path (based on a 3d polygon) to work, the profile twists seemingly uncontrollably from start to finish. Thanks! Quote Link to comment
Guest Posted March 16, 2007 Share Posted March 16, 2007 (edited) There's an untwist command to help reduce the twisting .. "Unrotate 3D objects" under the Modify menu Edited March 16, 2007 by Katie Quote Link to comment
willofmaine Posted March 16, 2007 Author Share Posted March 16, 2007 Thanks Katie; never would have found that command! But, in this case, it didn't seem to do anything... Quote Link to comment
Jonathan Pickup Posted March 16, 2007 Share Posted March 16, 2007 could you use the Extract Curve tool to extract the surface of the wall? maybe you could then use the protrusion tool to make it the size you want Quote Link to comment
islandmon Posted March 16, 2007 Share Posted March 16, 2007 The twist is created by the bezier vertices as they fluctuate around the axis in the Z dihedral. One way to correct this situation is to constrain the bezier dihedral to Z values equal to the top of the wall, only. In other words, lateral precessional vectors. Quote Link to comment
willofmaine Posted March 18, 2007 Author Share Posted March 18, 2007 Thanks for the responses. I didn't have much luck with using the Extract Curve tool; in any case, the cap is wider than the wall, so I'm not sure it would help even if I could get it to work. How does one 'constrain the bezier dihedral to Z values'?........ Quote Link to comment
islandmon Posted March 18, 2007 Share Posted March 18, 2007 The NURBS Path occupies a 12d VectorSpace. Assuming a 90? arc for the curve and 5? Rise of the wall , the NURB must use XYZ coordinates of arc curve based on the radius centered at XYZ, then the NURB requires a Bezier control point opposite the center @ 45? on the outside of the arc. The angular deflection between these 2 controls is the dihedral of the curve. For minimal 'twist' of the profile the dihedral angle should be equal to the Rise angle. Therefore, you will need to add back the angular difference of 5? to the base of the Cap Profile if you want it to sit flush on top of the wall object. Quote Link to comment
willofmaine Posted April 2, 2007 Author Share Posted April 2, 2007 Thanks Islandmon. By changing the angle of rotation of the profile (if that's what you're suggestion) I've been able to 'minimize' the twist in that instead of the start being flat and the end very twisted, both start and end were twisted half as much. I think next time maybe I will try using combinations of sweeps and straight, sloped extrudes...; though in all cases a single path that could be manipulated would be best... Quote Link to comment
