Damon Design Posted November 24, 2006 Share Posted November 24, 2006 I've never attempted to use this tool until just now. I obviously must be doing something wrong but have a simple gable roof and the walls (10' high) all revert to a 0' height when I invoke this tool to constrain to the tops of the walls. The walls will take on the height of the wall top embedding depth parameter-which is default 0", I presume because it will work fine with that input unless you have thick walls or very steep roofs-and if I input any number to that parameter the walls take that height, but do not ever constrain to the geometry of the roof. It seems to be such a straightforward action/tool that I am stumped by inability to do this- though that is not all that uncommon ;-) Thanks for any help between your turkey sandwiches. Tad Quote Link to comment
P Retondo Posted November 24, 2006 Share Posted November 24, 2006 Tad, I had trouble with this, too, in the latest version. Two things to watch out for: you can fit to objects BELOW or objects ABOVE, plus you can pick the LAYER on which the horizontal objects are found. Be careful about these things, and I think it will work for you. Quote Link to comment
Jonathan Pickup Posted November 25, 2006 Share Posted November 25, 2006 simple gable roof... turn off create gable end walls put roof in a separate layer from the walls check layer settings (Z and delta Z) for wall layer and roof layer Quote Link to comment
Damon Design Posted November 26, 2006 Author Share Posted November 26, 2006 Apparently the roofs need to be on a different layer. That is what solved the problem. Thanks for your suggestions. T Quote Link to comment
