cassey Posted September 5, 2006 Share Posted September 5, 2006 i'm new in vectorwork, i need so help to know how can i key in a simbol, such as "diameter", "degree", "radius" ect. thank you. Quote Link to comment
Christiaan Posted September 5, 2006 Share Posted September 5, 2006 It depends of which system you're using (Windows or Mac OS), and the keys are not specific to Vectorworks either. In Mac OS X degrees is alt 0, diameter is alt o, and radius is Alt p Quote Link to comment
jan15 Posted September 5, 2006 Share Posted September 5, 2006 In Windows, you get special characters by typing a 4-digit code on the numeric keypad while holding down the Alt key. The codes can be different for different fonts. You can find any code for any installed font by using the program "Character Map" which comes with Windows (Programs > Accessories > System Tools). In the font that I use for drafting, the degree symbol is alt-0176 and the circumference symbol is alt-0216. Quote Link to comment
cassey Posted September 6, 2006 Author Share Posted September 6, 2006 first, thanks a lot for reply my post. previosly in version VW8.0, i can do like that, but that is long time ago, now i start using VW 11.0 i cant do that.... nothing happen after i key in alt-0216. i think i still need more help... vectorwork 11.0 windows xp Quote Link to comment
MikeC Posted September 6, 2006 Share Posted September 6, 2006 You must use the numeric key pad and the num lock must be on ? it works for me ! Quote Link to comment
cassey Posted September 6, 2006 Author Share Posted September 6, 2006 mike, it seem still not works for me. the num lock is on .nothing happen after key in the alt-number. is there any setting inside the VW that i should turn on or off? cassey vw 11.0 windows xp Quote Link to comment
Itchy Posted September 6, 2006 Share Posted September 6, 2006 Can you use the symbols on this forum? in MS word? if they work fine in them then i would assume a setting has been changed in VW, thats if there is one, if you cant do them anywhere maybe its a computer setting rather than a VW setting. Quote Link to comment
cassey Posted September 7, 2006 Author Share Posted September 7, 2006 Xsasinator, i cant use the symbols on this forum or MS word i think you are right. but how and where to fix my computer setting? anybody, pls HELP.... Quote Link to comment
Ray Libby Posted September 7, 2006 Share Posted September 7, 2006 Are you holding down the ALT key while you type the numbers? You can always copy & paste from Character Map. Quote Link to comment
panthony Posted September 7, 2006 Share Posted September 7, 2006 cassey, If XP is not set up to recognize character mapping than you must do so. Check to see if you have the right set up...go to http://www.unicode.org/ and see what they have to say and also follow the windows help system to see how to set up your system to recognize mapping. Pete A Quote Link to comment
cassey Posted September 7, 2006 Author Share Posted September 7, 2006 (edited) THANK YOU all for all the advice... i solve the problem already. in fact, i'm using laptop for doing VW, so,my friend told me that i need to hold down 'Fn'+'Alt'+ number. so problem solve, thanks again.hahaha... Edited September 7, 2006 by cassey Quote Link to comment
