Aggie463 Posted July 12, 2006 Share Posted July 12, 2006 I know this is elementary, but I have no idea how to render windows and other things with both glass and another material. How do I do this? Quote Link to comment
CipesDesign Posted July 13, 2006 Share Posted July 13, 2006 Do you mean you want to have one material for the jambs/sills and another for the glazed area? If so, in the window SETTINGS there is a tab called VIEW and at the bottom is a pulldown called SPECIAL CLASSES. Assign STYLE 1 to the jamb, then go to the class setup dialog and edit the class called STYLE 1 so that it uses the desired texture at creation. HTH's Quote Link to comment
David_Ballantine Posted July 22, 2006 Share Posted July 22, 2006 Peter, I'm also a new to Renderworks and am having trouble with window glazing. When you say widow SETTINGS, are you talking about in the Obj Info Palette? I cannot find a VIEW tab there or a pulldown with SPECIAL CLASSES. Where exactly are you refering to. Thanks Quote Link to comment
ionw Posted July 22, 2006 Share Posted July 22, 2006 David, double click on the window, OR clock on the button Settings in the info palette. then in the window settings window comes up click on the view tab, HTH Quote Link to comment
Don@Black Dog Posted July 22, 2006 Share Posted July 22, 2006 Peter's answer is most helpful, but what if we want to change the glazing, ie to make a screen or lattice appearance? Change the window class texture then restore the jambs with the Special Classes procedure? It would be nice to have glazing in the special classes options list.... Quote Link to comment
Michael_Eschenbach Posted July 26, 2006 Share Posted July 26, 2006 I agree... wish list item.... it would be nice to have 'glazing style 1-3' in the special classes. It would also be nice to have glazing as one of the 'parts' in the special classes section. Quote Link to comment
Christiaan Posted July 26, 2006 Share Posted July 26, 2006 You can guys, see this thread: http://techboard.nemetschek.net/ubbthreads/showflat.php?Cat=0&Board=UBB16&Number=61028 Quote Link to comment
Don@Black Dog Posted July 26, 2006 Share Posted July 26, 2006 I tried that with a texture Katie had sent me, but it applied it to the whole window, not letting me isolate the glass. Unless I did it wrong... Quote Link to comment
Christiaan Posted July 27, 2006 Share Posted July 27, 2006 I'm able to do it so I guess you're doing something wrong. Try creating a new file, draw a wall and put a window in it and then try it (i.e. rather than using an existing project). Quote Link to comment
