gmh
HP DesignJet 120
I need to purchase a plotter that will allow me to plot 24X36 primarily B/W from VW on Mac platform. The HP DJ120 seems pretty reasonable but would like to get some feedback from people out there with experience on this plotter. Is the roll feeder a must?
Thanks in advance.
12 answers to this question
The roll is. For my HP 430 I bought a four foot tall bookcase, put the printer on top and installed a hang rod for the roll paper. Good storage for printing materials. Instead of the basket to catch the prints I have a table in front of it to catch them and sort.
I would be sure that the software is compatible. I have found HP software for the Mac to be buggy. I have the HP 455CA (with roll feed). There is no HP software for OSX for this plotter. It currently runs fine with Gimp Print, but runs slow.
When I ran it under OS9 with the HP software, it was often a headache. HP seems to view the Mac as an afterthought.
You still can use plotter ppd file for OS9 on OS X, When U setup the printer, select the ppd fil manually. Normally it work. I have try it on
HP1055cm, HP755CM, HP5100tn, HP4100, HP4M, HP5M, TDS400 & TDS800.
G-Pang: Could you explain this further. I am not sure what you are trying to say.
You can use ppd file if your plotter come with postscript feature. Otherwise I recommend to use LPD print server. I had explain about LPD server somewhere in this forum.
We just got the HP 130nr yesterday. To my delight (and almost surprise), the software is OK at least with OS X - there is also an OS 9 version, but I have not tested it yet. So, Kevin - you may need to reconsider your general opinion... (and yes, I know exactly how bad the 455CA is!)
Whether one needs roll feed is a somewhat complex matter: if you almost always print on one medium OR if you have long print runs (either drawings or copies), roll feed is definitely better, but if every other print is different OR you don't print much, the benefits are less significant. Location of the printer also matters - if it is next to your workstation (as it would be without network connection!), sheet feed is not too bad.
Petri,
Are you using Verson 11 with your 130nr? And what verson of OSX are you running?
Thanks,
Larry
Petri
I?ve read in previous posts that the now discontinued designjet 120/120nr could not produce good quality black CAD lines in normal paper, what can you tell us about the 130nr? is it as noisy as the 120?
thanks
Ricardo
quote:
Originally posted by LarryAZ:
Petri,
Thanks,
Larry
Sorry to have been away...
VW 9 and also VW 11 Viewer (in fact, to test the configuration) with OS X 10.3.3 & 10.3.4.
Ahh, yes: also with OS 9.2.2, (The plotter comes with an OS 9 driver - non-PS, fully functional! Fancy THAT!)
[ 06-18-2004, 11:05 AM: Message edited by: Petri ]
quote:
Originally posted by Ricardo:
Petri
thanks
Ricardo
Black lines seem OK to me on normal bond paper. I have no idea how noisy the 120 is, but the 130 is quite quiet except for a click for each stripe. Does not bother me.
I just got my 130nr setup. I'm running the latest version of OSX and VW11. Everything worked perfect first time. Print quality seems to be fine. The roll feeder is really easy and cuts a perfect size D. On the noise the fan is a little noisy but the printing seems pretty quiet. This iMac is so quiet anything seems noisy compared to it.
Anyway, I'm happy so far. Thanks for the info.
Larry
Hi to all hp130 users. I'm interested in all of you who seam to have been able to use the 130 without problems. I've got the 130, not the 130nr and had to get additional software off microspot to be able to print from VectorWorks (other applications are fine) - something to do with the 130 not supporting the vector file format.
How are you managing to make it work without additional software?.
I'm using WVA11 and OSX 10.3.4
