Currently if you use the replace symbol function repeatedly it takes you back to the root level of your resources each time.
It would work better if it took you back to the last replacement symbol you chose (until you close and reopen the file, in which case it could take you to the root again).
An example of when this would be useful is where you're working your way through a number of layers replacing the same window on each level.
Christiaan
4 answers to this question
