Delmer Posted March 28, 2005 Share Posted March 28, 2005 Yes, when I stick a window on a wall I generally want it inserted, but stairs and cabinets popping into walls is not right. Quote Link to comment
0 CipesDesign Posted March 29, 2005 Share Posted March 29, 2005 If you deselect the "wall insertion mode" option, in the upper left section of the drawing, objects will not insert. Hope that helps. Quote Link to comment
0 mike m oz Posted March 29, 2005 Share Posted March 29, 2005 Peter's way is the quickest and easiest. The other option is to use a different Class to the walls for your objects (you should be doing this anyway). If you draw with the Class Options set to Show / Snap Others the symbols cannot interact with the walls (the same applies to Plug-in objects). [ 03-28-2005, 07:42 PM: Message edited by: mike m oz ] Quote Link to comment
0 Delmer Posted March 29, 2005 Author Share Posted March 29, 2005 Both Very helpful, both I was aware of but for some brain fart reason had forgotten -though I have to admit I haven't toggled between Class Option modes much. Thanks for pointing out why I should. Quote Link to comment
0 Petri Posted March 30, 2005 Share Posted March 30, 2005 Still, this is a serious design fault in PIOs and symbols. Quote Link to comment
0 mike m oz Posted March 30, 2005 Share Posted March 30, 2005 I agree with Petri Only doors and window PIO's and symbols should interact with the walls. Almost verything else shouldn't. - Snap to the wall yes. - Become attached to the wall no. You can present a case for columns and pilasters to also interact with the walls but for me snapping to the wall would be sufficient. Quote Link to comment
Delmer
5 answers to this question
