AlanW Posted May 2 Share Posted May 2 Hi is there a way to have the text in a symbol remain horizontal when i rotate it. Thanks in advance Symble text rotate.vwx Quote Link to comment
0 Vectorworks, Inc Employee tdiamond Posted May 2 Vectorworks, Inc Employee Share Posted May 2 Hello Alan, Try the Electrical Services Tool in the MEP toolset… Quote Link to comment
0 AlanW Posted May 2 Author Share Posted May 2 Will look at this. The way i am using this is is the symbols reference a record folder and a worksheet is used as our legend schedule so the worksheet only places the symbols used in the legend and not every symbol See attached Untitled 9.vwx Quote Link to comment
0 Vectorworks, Inc Employee Peter Neufeld. Posted May 11 Vectorworks, Inc Employee Share Posted May 11 Hi Alan, To answer your question the reason is because it is a 3D only symbol. If you cut the objects from the 3D component and paste into the 2D then the document preference of 'Adjust Flipped Test' can then work. Otherwise the objects are just planar objects in 3D. Troy is correct in that you should look at the ANZ Electrical Services tool. Right click on the page and go to the ANZ Video Tutorials to see the two about it's use. Cheers, Peter Quote Link to comment
AlanW
Thanks in advance
3 answers to this question
