Fencing issues
BSD
Hi there,
VW24 update 3.1 - Having a couple of issues with the fencing tool settings:
  • When I plot a spigot mounted glass pool fence the start post never lines up with the first panel. I can't seem to edit it into place either. See attached screenshot.
  • When I change the standard fencing settings from raked to stepped (to follow the step down of a retaining wall), the posts and panels separate and I can't seem to edit them back together. See attached screenshot.
Would appreciate any tips on what I'm doing wrong here.
fence and post separation.pdf
3 answers to this question
Check your corner post settings. Looks to me like you get better results when you use the same symbol for run post + corner post.
I don't know why 'Vertical Boards' is doing this but if you change the Infill Type to 'Panel, Pre-Constructed' it works as expected. I don't use Stepped configuration but I'm sure someone else will know what's happening.
