This has probably been discussed previously, but you know the old saying..."the squeeky wheel gets the grease'. 🙂
I realize 'sloped' walls have long been on the wishlist, Â but it would also be desirable to be able to angle the left and/or right sides of a wall in elevation.
You can add peaks, etc but splaying a wall where the top is wider than the bottom doesn't seem possible...unless I am just totally missing something.
Â
Case in point, check the screenshot and note the splayed wall next to the yellow arrow. I did some workaround tricks to facilitate this, but it would sure be nice if the wall tool could create walls like this....top wider than the bottom.
Kevin K
Â
Â
5 answers to this question
