LeeElston Posted March 15 Share Posted March 15 I have an issue where whilst the revision no, description, and other info created from the revision data in the Title block manager, the date does not align, being regularly spaced up the column. If I go into the title block layout to edit the position, only the most recent revision is visible, so no way of alining manually... Any suggestions? Quote Link to comment
Tom W. Posted March 15 Share Posted March 15 Try setting the vertical alignment of the date placeholder text in the Title Block Layout to 'Bottom'. I can see it's currently set to Top whereas the rest of the revision text looks to be correctly set to Bottom. 1 Quote Link to comment
line-weight Posted March 15 Share Posted March 15 I had a similar problem to this, with keynote legends. I think in the end I worked out it was somehow related to odd line spacing in the text (or text style) used. Changing the line spacing seemed to sort it. Quote Link to comment
LeeElston Posted March 16 Author Share Posted March 16 Tried Tom W's suggestion but even with all text blocks having bottom centre setting, still happens. Also, all are set for single spacing. I suppose this could be set for a set s distance but if the next revision was only 1 line the date would still be put, say, 4 lines above so the same problem in reverse... Quote Link to comment
Tom W. Posted March 16 Share Posted March 16 It works fine for me: Unless I'm misunderstanding what you're after. Quote Link to comment
LeeElston Posted March 16 Author Share Posted March 16 Sorted it.. there is a check box in the title block data that sets the text to align to top by default... Thanks 1 1 Quote Link to comment
Tom W. Posted March 16 Share Posted March 16 (edited) 7 minutes ago, LeeElston said: Sorted it.. there is a check box in the title block data that sets the text to align to top by default... Thanks I never noticed that check box before! That changes my layout to this: Which I prefer! Thank you! Edited March 16 by Tom W. Quote Link to comment
