Marcus bLD Posted March 4 Share Posted March 4 Hi, Could anyone tell me why I can't see my fence posts? I've worked out how to get the mesh to show (adding texture in Render under OIP). I've coloured the posts black but they keep showing as the fence mesh. I always find I can get 90% through this type of thing and always get stuck on the last step, I feel I am missing part of a workflow. Thanks Quote Link to comment
Tom W. Posted March 4 Share Posted March 4 2 hours ago, Marcus bLD said: I've worked out how to get the mesh to show (adding texture in Render under OIP). You should be applying the textures to the different parts of the Fence in the 'Attributes' tab of the 'Fence Style' or 'Fence Settings' dialog. In fact I'm not sure whether the OIP render settings affect the object at all in VW2024 so does that mean you're actually using the previous Railing/Fence tool...? You should include your VW version in your signature. In VW2024 the Railing/Fence tool was replaced with the separate Railing + Fence tools. But if you are using the VW2023 tool the same thing applies: you need to apply the textures in the '3D Attributes' tab of the settings. Quote Link to comment
Marcus bLD Posted March 4 Author Share Posted March 4 Thanks, yep I'm using 2024. I've just watched the coffee break tutorial on it, but still no luck. The posts below are grey when you zoom in and the rails aren't showing but they are all black in the attributes (the rails don't show up in the preview in attributes which is interesting) but they show up in the Infill tab. Quote Link to comment
Jonathan Pickup Posted March 4 Share Posted March 4 you have given the posts a black colour but no texture. give the posts a material with a texture Quote Link to comment
Marcus bLD Posted March 4 Author Share Posted March 4 They are steel gal posts but for some reason they are greyed out in the Attributes so can't be changed. Quote Link to comment
Tom W. Posted March 4 Share Posted March 4 2 minutes ago, Marcus bLD said: They are steel gal posts but for some reason they are greyed out in the Attributes so can't be changed. Are they are taking their texture from the 3D symbol? Quote Link to comment
Tom W. Posted March 4 Share Posted March 4 For the posts you can either use a profile in the form of a 2D-only symbol or a 3D object in the form of 2D/3D hybrid symbol. If you use a 2D-only symbol the PIO extrudes the profile + uses the attributes as specified in the settings. If you use your own 3D-modelled hybrid symbol the attributes come from the symbol + therefore those attribute parameters are greyed out in the settings. (If you use a 3D-only symbol the post will have no Top/Plan representation so you need to make sure it's a hybrid symbol.) Quote Link to comment
Marcus bLD Posted March 4 Author Share Posted March 4 I've just removed the texture from the symbol but it's still greyed out Quote Link to comment
Tom W. Posted March 4 Share Posted March 4 Just now, Marcus bLD said: I've just removed the texture from the symbol but it's still greyed out As above if you want to specify the texture in the Fence settings you need to use a 2D symbol for the post Quote Link to comment
Marcus bLD Posted March 4 Author Share Posted March 4 Not sure if this is a silly question, but why would I want to specify the fence texture anywhere other than the fence settings? Quote Link to comment
Tom W. Posted March 4 Share Posted March 4 16 minutes ago, Marcus bLD said: Not sure if this is a silly question, but why would I want to specify the fence texture anywhere other than the fence settings? It is just the way the new tool works. Using symbols actually makes it far more powerful than the previous tool. You just need to create different symbols for different posts then switch between them in the settings ('Posts' tab). So duplicate the steel post symbol you are using, change the texture in the new symbol to black paint then use that symbol in the Fence. Or if you're happy for your post to just be an extrude, use a 2D profile. Then you can set the texture in the Fence settings. It's a bit like when you use a Custom Leaf in a Door: the leaf takes its textures from the symbol, you can't edit them from the Door settings. But Custom Leaves give you far more flexibility than the leaves the PIO creates. Quote Link to comment
Marcus bLD Posted March 4 Author Share Posted March 4 Thanks Tom (and Jonathan), I'll be playing around with it this morning. Quote Link to comment
Marcus bLD Posted March 4 Author Share Posted March 4 Sorry, I'm still not quite getting this. I go into the fence tool, choose the type of fence I want, which has pre-specified posts, rails and infill already configured but these won't show up on my drawing unless I then go in and add a texture for each of the already pre-determined materials? So you are kind of getting the fence style but then need to customise the textures? I tried a different fence out of interest, it's called a fence wood split rail and it is just outlines so I assume this is the same, there are currently no textures. Which leaves one question, where/how do I apply the texture? I know it's not through the fence tool, so is it through the Render tab in OIP, or do I need to find it in the Resource Manager, import it and then customise it and save it as a symbol? Thanks again Quote Link to comment
Tom W. Posted March 5 Share Posted March 5 I am not aware of any of the stock VW Fence styles displaying without textures. They should all work out of the box. It would be easier to diagnose what's going wrong for you if you posted a file Quote Link to comment
Jonathan Pickup Posted March 5 Share Posted March 5 If you have use a 3D post profile, you might find that you have to edit the 3D post to add the texture. Quote Link to comment
Marcus bLD Posted March 5 Author Share Posted March 5 (edited) Hi Tom, yes that was what I couldn't understand, I assumed they should just work. Please see One Drive link below. As you will see the fence is there and sitting on site model, but rails are only showing as outlines.. and I tried adding a gate but that didn't work - it was wooden and too high, no option for a chainwire/fabric one - even after I changed all the settings. I watched a 1.5 hour coffee break session on the new fence tool from VW Europe, and they didn't encounter these issues, I appeared to do everything the same. Also having some issues getting a couple of items to attach to the site model but that's tomorrows problem. I've spent about 8 hours working on this fence now, ouch. Thanks Share copy SE fence issue.vwx Edited March 5 by Marcus bLD one drive link issue Quote Link to comment
Tom W. Posted March 5 Share Posted March 5 Unfortunately the link didn't work...? Quote Link to comment
Marcus bLD Posted March 5 Author Share Posted March 5 https://1drv.ms/u/s!AiKGnIIvNkiJg_kqY3KCVw6ewyijkg?e=cPhQme Try this one? Quote Link to comment
Tom W. Posted March 5 Share Posted March 5 The problem is that your None class is set to have no fill. The 3D symbol you are using for the rail has its geometry in None class + is set to take it's fill by class therefore it has no fill. And because it has no fill it is not displaying its texture. So the problem is with your file, not any of the resources. Objects need to have a fill in order to display textures. The galvanised post symbol also has its geometry in None class but this time is not set to take its fill from the class, instead it has a solid fill in the attributes palette. This is why this symbol is showing its texture. Edit None class + change fill from None to Solid + you get this: Or edit the 3D component of the rail symbol + give it a fill in the attributes palette. Quote Link to comment
Marcus bLD Posted March 5 Author Share Posted March 5 OK, that's really helpful thanks Tom, I've now changed the Class, and will play around with that a bit more. Really appreciated mate. 1 Quote Link to comment
