Leandrovsk Posted February 29, 2024 Share Posted February 29, 2024 How do I get the walls above the intermediate component of the slab? Quote Link to comment
Jeff Prince Posted February 29, 2024 Share Posted February 29, 2024 There are many ways, depending on your intended outcome. Here are a few methods: Setting a Bottom Wall offset = to the thickness of your slab component. Changing your layer wall elevation to correspond to the elevation of your intermediate slab component is another. If you are using walls with components, you can change the bottom offset of the component(s). If your wall bottoms sit at the correct elevation, you use "clip surface" to trim the slab with the walls... this invokes the special special "clip shape from slab" dialog box where you can select what slab components will be trimmed by the wall. Will one of those suit your situation? Quote Link to comment
Leandrovsk Posted March 1, 2024 Author Share Posted March 1, 2024 4 hours ago, Jeff Prince said: There are many ways, depending on your intended outcome. Here are a few methods: Setting a Bottom Wall offset = to the thickness of your slab component. Changing your layer wall elevation to correspond to the elevation of your intermediate slab component is another. If you are using walls with components, you can change the bottom offset of the component(s). If your wall bottoms sit at the correct elevation, you use "clip surface" to trim the slab with the walls... this invokes the special special "clip shape from slab" dialog box where you can select what slab components will be trimmed by the wall. Will one of those suit your situation? Yes! I did it, thank you very much. Sorry for writing the subject in Portuguese... 1 Quote Link to comment
Leandrovsk Posted March 1, 2024 Author Share Posted March 1, 2024 (edited) 14 hours ago, Jeff Prince said: Will one of those suit your situation? Hi Jeff, maybe you can help me with another point, I created another slab on the lower floor, but in it the walls show the line of the upper component of the slab, I looked in all the settings but I'm not finding where I can hide this line. The component line should not cross the wall cut. It's the same style of wall as the upper floor, it's the slab that's different, so I think it's some configuration of the slab, but I can't find where. Thank you Edited March 1, 2024 by Leandrovsk Quote Link to comment
Jeff Prince Posted March 1, 2024 Share Posted March 1, 2024 Hmm. Did the clip method not work? I know people in the past have had to stop there slabs at the top of structure and create separate objects to represent the floor finish in this circumstance. Perhaps @Tom W. Can help. Quote Link to comment
Tom W. Posted March 1, 2024 Share Posted March 1, 2024 Clipping the upper component/s in 2D should definitely work but yes like Jeff says I prefer to do the floor as two Slabs: one overall structural Slab that the internal walls sit on + a separate Slab (or Slabs) for the floor finish which runs up to + around those walls... (And actually the same for ceilings if applicable) 1 Quote Link to comment
Leandrovsk Posted March 1, 2024 Author Share Posted March 1, 2024 I'd like to try the same slab, I'm insisting. Upstairs it worked, I've checked all the wall and slab configurations on both floors and they're the same. I don't know where the trick is... I'm trying to draw with as few elements as possible, preferably without cutting or adding volumes to slabs and walls. Quote Link to comment
Leandrovsk Posted March 1, 2024 Author Share Posted March 1, 2024 I found out! Upstairs I was using several slabs, while downstairs it's a whole slab, so there are no offsets near the wall in the middle. However, the correct way for the floor to be represented would be an interrupted line in the middle of the wall, is this a limitation of the vector? Quote Link to comment
Leandrovsk Posted March 1, 2024 Author Share Posted March 1, 2024 I'm going to open another thread with just this question to see if anyone can help us. Quote Link to comment
Ross Harris Posted March 4, 2024 Share Posted March 4, 2024 I prefer to do floor finish slabs on top of the structural slab so I can schedule/quantify all the floor finishes. Plus, all our floor finishes except polished slabs are inside walls, so is 'construction correct'. 2 Quote Link to comment
Tom W. Posted March 4, 2024 Share Posted March 4, 2024 17 minutes ago, Ross Harris said: I prefer to do floor finish slabs on top of the structural slab so I can schedule/quantify all the floor finishes. Plus, all our floor finishes except polished slabs are inside walls, so is 'construction correct'. Also allows you to have different finishes in different rooms whilst maintaining the same structural slab across the whole building. And makes controlling visibility easier in terms of displaying the structural model (I have the structural slab on one layer + the floor finish slabs on another layer). 2 Quote Link to comment
Leandrovsk Posted March 11, 2024 Author Share Posted March 11, 2024 Thanks for the tips. Quote Link to comment
