Label Legend - Size of container type
Containers do not automatically resize. If you want larger containers or different shape containers, draw the shape you want for the container and create a symbol from the shape.
Place the symbol in the containers folder and the shape will be available for you to select when you use the label legend manager.
I will try, thank you for your help
Will be a good upgrade. I trust in you @klinzey 🙂😁
Edited by Cristiano Alves
Now I realize another problem.
Use Universe/Adress is useless because this attribute has a bug (probably)
I try use a text box to write a "/", and we can't use text too?
The result:
