Tobias Kern Posted February 8, 2024 Share Posted February 8, 2024 HI there, I have a Data Tag for getting out the thicknesses of wall components. The code of the Data Tag look like this: #WS_IF(COMPONENTTHICKNESS(1)<>0; TXT(COMPONENTTHICKNESS(1); 'Millimeters'; 'Units'); '')# #WS_IF(COMPONENTTHICKNESS(2)<>0; TXT(COMPONENTTHICKNESS(2); 'Millimeters'; 'Units'); '')# #WS_IF(COMPONENTTHICKNESS(3)<>0; TXT(COMPONENTTHICKNESS(3); 'Millimeters'; 'Units'); '')# #WS_IF(COMPONENTTHICKNESS(4)<>0; TXT(COMPONENTTHICKNESS(4); 'Millimeters'; 'Units'); '')# #WS_IF(COMPONENTTHICKNESS(5)<>0; TXT(COMPONENTTHICKNESS(5); 'Millimeters'; 'Units'); '')# #WS_IF(COMPONENTTHICKNESS(6)<>0; TXT(COMPONENTTHICKNESS(6); 'Millimeters'; 'Units'); '')# #WS_IF(COMPONENTTHICKNESS(7)<>0; TXT(COMPONENTTHICKNESS(7); 'Millimeters'; 'Units'); '')# #WS_IF(COMPONENTTHICKNESS(8)<>0; TXT(COMPONENTTHICKNESS(8); 'Millimeters'; 'Units'); '')# The problem is that the data tag displays empty rows if a wall has fewer components than 8. Please look at the screenshot. Is there a way to write an "operator" or something else (maybe with regex) to get "EMPTY" if nothing is given out? I know we have "ELSE" for: =IFS() "ELSE" is not documented anywhere Maybe a "EMPTY" or something else exists, if a nothing is given out? Could this be a useful wish, I mean "EMPTY" as new option for Data Tags? Attached VW 2024 demo file Greetings and many thanks for your help. Tobi Test Data Tag.vwx 2 Quote Link to comment
Tom W. Posted February 8, 2024 Share Posted February 8, 2024 15 minutes ago, Tobias Kern said: The problem is that the data tag displays empty rows if a wall has fewer components than 8. Please look at the screenshot. Why is this a problem? You only know the empty rows are there whilst the tag is selected. I have several multi component tags like this Quote Link to comment
Tobias Kern Posted February 8, 2024 Author Share Posted February 8, 2024 Hi Tom, sure it is "only" a visual problem. I thought it would look nicer without the empty rows. Greetings Tobi Quote Link to comment
Tom W. Posted February 8, 2024 Share Posted February 8, 2024 OK thanks for confirming 👍 Quote Link to comment
Pat Stanford Posted February 11, 2024 Share Posted February 11, 2024 Untested, but put the entire function on a single line so there are no manual line breaks. The CHAR(10) in the function will add the line break. I have only included one line but you will need to use a similar code as below for each block #WS_IF(COMPONENTTHICKNESS(1)<>0; CONCAT(TXT(COMPONENTTHICKNESS(1); 'Millimeters'; 'Units'),CHAR(10)); '')# Quote Link to comment
