Sheet numbering
Late on in a project, a client has advised they need all of their own drawing numbers on the tender documents, rather than the ones we have created so far. By default the Title block uses the sheet number to populate the 'drawing no' box on the Title block . I Can create additional fields in the 'Title block border settings' to create a client drawing number, which I can link the text in the title block to, but if I publish all of the sheets as pdf's,  they will be titled from the Sheet number and title rather than the client drawing numbers wanted. Is there a way of creating a second sheet number list to run in parallel with the default list? I can just swap the numbers around but with a lot of drawings will be tedious and open to mistakes... TIA
If this is the crux of the problem can you not just create a custom naming scheme in the File Export Options that gives the PDFs the name you want?
