Backup file is crashing!
lomaxnancy77
My main file is crashing Vectorworks, and my backup file from about an hour ago is also crashing the program. My program is up to date, and I've restarted my computer AND the program. Edited to add that I am updating my OS software on my Mac right now. The termination reason given in the report is: Namespace SIGNAL, Code 11 Segmentation fault: 11
I hesitate to copy/paste the entire report here as it's pretty long. But I will if requested/needed.
Thoughts? Solutions?
TIA!
Edited by lomaxnancy77
4 answers to this question
I’ve had this happen once or twice, sometimes files get so broken the only thing you can do is try to recover the file.
1) Hopefully you have more than one backup file and you can try and find an older one that doesn’t crash Vw.
2) If that is not the case, you could try to recover the file using the ‘layer import’ tip described in the following thread. It may or may not work for you. The last time I tried this it didn’t work for me; it kept crashing when I tried to import the Layers.
Good luck.
