Wood Posted December 1, 2023 Share Posted December 1, 2023 (edited) Hello, I'm trying to create a center pivot truss hinge from scratch. Once I select the appropriate settings in the truss properties dialog, it breaks the 3D geometry. If I insert symbol using the truss tool with these settings, nothing is visible unless I enable draw centerline in the OIP, which then just shows the red and blue handles. All objects, both 3D and 2D are gone. Also, how do you tell VW which parts pivot? Editing to add: This hinge is primarily used to pivot left to right, and I'd like the default symbol to reflect that. This dialog only allows pivot up and down per the Topview and Frontview illustrations. Thanks! Edited December 1, 2023 by Wood more info 1 Quote Link to comment
Vectorworks, Inc Employee JustinVanHassel Posted December 1, 2023 Vectorworks, Inc Employee Share Posted December 1, 2023 @WoodCenter pivot truss hinges only pivot up and down and that is how the code is setup for safety reasons. Only book hinges can pivot left to right. In order to make your hinge pivot left to right you need to setup the symbol as shown in the diagram as a pivot up and down hinge. Then when you insert the hinge you use the roll field in the OIP to roll it 90° which will strip the 2D geometry and then redraw a properly oriented 3D version. From there you can use the settings in the OIP to pivot the hinge as you desire. Did you assign the proper BrxHingePart record to both the left and right portions (which should be groups) of the hinge in both the 2D and 3D? Once that record is attached you can set which part of the hinge you are labeling with either left or right and 2D or 3D. This is how you get the parts to pivot. If make all the truss symbols that ship with the software so if you have more questions let me know as I know it is confusing sometimes to setup hinges. Quote Link to comment
Wood Posted December 1, 2023 Author Share Posted December 1, 2023 Thanks Justin! I didn't know about the records, so I'll give them a shot. Is there any documentation on this that I can study? Quote Link to comment
Vectorworks, Inc Employee JustinVanHassel Posted December 1, 2023 Vectorworks, Inc Employee Share Posted December 1, 2023 There are some internal documents that were written for the developers when teh hinges were implemented. I will see if I am allowed to let that stuff leave the building so to speak. Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted December 1, 2023 Vectorworks, Inc Employee Share Posted December 1, 2023 4 hours ago, Wood said: I'm trying to create a center pivot truss hinge from scratch. I made a video a while back that might be helpful. I'm not sure, as I made it before Magnets showed up. 1 Quote Link to comment
Vectorworks, Inc Employee JustinVanHassel Posted December 1, 2023 Vectorworks, Inc Employee Share Posted December 1, 2023 Scott's video will definitely help and the magnets aren't that difficult, just have to add them into each group so they move with the hinge. Quote Link to comment
Vectorworks, Inc Employee JustinVanHassel Posted December 12, 2023 Vectorworks, Inc Employee Share Posted December 12, 2023 @WoodDo you still need this information. I have been given approval to share the document. Quote Link to comment
aheininen Posted December 14, 2023 Share Posted December 14, 2023 I am interested of that documentation. Even modifying hinges were a bit try and fail until you succeed method. Comparing how other symbols from library were constructed helped too. I'm sure documentation would be a lot of help. Quote Link to comment
Vectorworks, Inc Employee JustinVanHassel Posted December 14, 2023 Vectorworks, Inc Employee Share Posted December 14, 2023 @aheininenI have sent you a DM with the information. Quote Link to comment
Wood Posted January 10, 2024 Author Share Posted January 10, 2024 @JustinVHSorry I've been away from the forum. Yes, I'd love that documentation. I'm currently building libraries for one of our vendors and they have quite a few items. Thank you! Quote Link to comment
Sebastian Giese Posted January 14, 2024 Share Posted January 14, 2024 @JustinVH Can i please get the document too? Quote Link to comment
