Ramon PG Posted November 2, 2023 Share Posted November 2, 2023 How can I get to show my doors and low walls? The classes are active and if I view the plan in 3D the door sna low walls will show. The table is from the Tool Set and it's really weird, too. Quote Link to comment
0 Pat Stanford Posted November 2, 2023 Share Posted November 2, 2023 You will probably need to use a Horizontal Section Viewport so you can define the "cut plane" When you go to Shaded (or any render mode) the model switches from Top/Plan to Top. So you are seeing the 3D representation instead of the 2D. 1 Quote Link to comment
Ramon PG
1 answer to this question
