chaseurban Posted October 27, 2023 Share Posted October 27, 2023 Just upgraded from 2023 to 2024 and I can't seem to figure out where all my lighting objects went. I already installed the extra lighting fixture libraries. In 2023, you would just click on the lighting object tool, select your lighting symbol, and put it down. Now I have 0 symbols! I'm sure there's something simple I am missing here. Thanks in advance. Quote Link to comment
Pat Stanford Posted October 27, 2023 Share Posted October 27, 2023 Have you updated your library files from 2023 to 2024? VW can only access resources from files that are on the same version. Quote Link to comment
chaseurban Posted October 27, 2023 Author Share Posted October 27, 2023 I'm just trying to access the default fixtures built into spotlight. I shouldn't need to import anything right? They came automatically in VW23. Quote Link to comment
Pat Stanford Posted October 27, 2023 Share Posted October 27, 2023 Correct If you are using the default libraries they should be included. Check your VW Preferences:Session pane and make sure the options the Libraries are checked. Quote Link to comment
chaseurban Posted October 27, 2023 Author Share Posted October 27, 2023 I just checked and I had those options selected. I turned them off and then back on again but no changes. Quote Link to comment
Pat Stanford Posted October 27, 2023 Share Posted October 27, 2023 I am out of ideas. Maybe @Jesse Cogswell or another VW employee can help here. Sorry. Quote Link to comment
chaseurban Posted October 27, 2023 Author Share Posted October 27, 2023 I'm thinking I just need to reinstall. Quote Link to comment
Jesse Cogswell Posted October 27, 2023 Share Posted October 27, 2023 I think @Pat Stanford meant to link Jesse Cogdell @jcogdell instead of me, I don't work for Vectorworks. But, I can do my best to help you. Can you post a picture of either your Resource Manager or the Resource Pop-up from the Lighting Device Tool? Resource Manager: Resource Pop-up: You shouldn't necessarily need to download the full library, you can download files on demand as you need them, but could you also post a picture of your Vectorworks Package Manager? It can be found by going to Help - Download Content. Finally, which operating system are you running? I strongly recommend putting your system information and which version of Vectorworks you are using in your signature (it's not quite where you expect it, but Pat has a handy guide in his signature). Quote Link to comment
michaelk Posted October 27, 2023 Share Posted October 27, 2023 1 minute ago, Jesse Cogswell said: to link Jesse Cogdell @jcogdell instead of me, I don't work for Vectorworks. 🤪 @Jesse Cogswell that must happen on a regular basis. btw if your ears were burning we were talking about Locate Class Objects in a recent SBVWUG meeting! Quote Link to comment
Pat Stanford Posted October 27, 2023 Share Posted October 27, 2023 @Jesse Cogswell Sorry Jesse. But what are the odds of getting two VW Spotlight Experts named Jesse Cog****. 😉 I will try to do better. 🤦♂️ 2 Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted October 30, 2023 Vectorworks, Inc Employee Share Posted October 30, 2023 @chaseurban From what you are describing It sounds like your resource manager cache has been corrupted, you don't need to reinstall to fix just delete the cache and then run the update library command The cache is in Users>******>AppData>Roaming>Nemetschek>RMCache 1 Quote Link to comment
chaseurban Posted October 30, 2023 Author Share Posted October 30, 2023 Thank you everyone for your help! I had to delete all of my personal user data and then reinstall. Quote Link to comment
chaseurban Posted October 30, 2023 Author Share Posted October 30, 2023 7 hours ago, jcogdell said: @chaseurban From what you are describing It sounds like your resource manager cache has been corrupted, you don't need to reinstall to fix just delete the cache and then run the update library command The cache is in Users>******>AppData>Roaming>Nemetschek>RMCache This probably would have worked but already fixed haha. Thank you! Quote Link to comment
