CSV Export using Python
I'm about to start on a task for taking given named worksheet, recalculating it and then exporting the contents as a CSV. I've started at the export bit and I'll look at getting the data to go in it later.
I started to use vs.PutFile, which allowed me to output a blank file, but Write, WriteLn etc weren't known by the interpreter. So I presume this is because Python should really be using more native ways for that kind of thing.
So, executing in PyCharm, I can export a CSV file using the below fine, but get 'Errno13'  'Permission Denied' if executing in VWX.
import csv
data = ["Circuit", "Cable", "Signal"]
filename = "output.csv"
with open(filename, 'w', newline='') as csv_file:
    csv_writer = csv.writer(csv_file)
    csv_writer.writerow(data)
If I specify a file path at the definition of the filename variable ("C:\.....output.csv"), I get this (I can't copy and paste from the script error log screen, hence the screenshot):
Is there a known working way to get a csv file to write from Python executed in Vectorworks?
the path has to be absolute when executing inside vectorworks. Not:
leaving it as "output.csv" is telling Vectorworks' python interpreter to save it the installation directory of vectorworks.
Try specifying a full path to another location eg.
filename = "C:\Temp\output.csv"
Also look at DataFrames for python using the pandas module. It has better functionalites for Data Wrangling.
You'll need to write your own module for converting a worksheet table to a pandas dataframe, then once its in dataframe format, you can do many things with that dataframe. Export to csv, xls, json, etc
Edited by twk
I did that, but I got the SyntaxError (unicode error) in my little screenshot. Uneducated guess that it's referring to the \ as an invalid character?
Great, thanks, will do. I'm aware of pandas but haven't used it yet, so I'll dive in to it.
10 minutes ago, JBenghiat said:
Unless this is part of a larger process, you can also export csv from the worksheet’s file menu
Thanks, I'm trying to make it slick and fast for some our of users to export a batch of specific worksheets in our template to a target folder for import to Access (bleughhh) for reporting. The slicker and faster I make it, the more likely they are to use it...
Really hoping that Paginated Worksheets come soon, so that I don't have to push out to an external app that understands paginated reporting. I can make some really nice reports, checklists etc in Access, but having to transfer all of the data externally is tedious (tried to get the ODBC thing functioning at one point, sod that...).
"C:\\Temp\\Output.csv" would work also
I would strongly recommend,  always create path strings with the path module. So it is as proof as it can be and this works also cross-platform:
import os
path = os.path.join('C:', 'Temp', 'Output.csv')
# or even more propper
path = os.path.join('C', os.sep, 'Temp', 'Output.csv')
