StefanoT Posted October 18, 2023 Share Posted October 18, 2023 Hello everyone, At the office we've been and we are - both VW2023 and VW2024 - experiencing on several files an unexpected behaviour from VW. Apparently, performing certain operations on "heavy" files (from our experience mainly with 3d geometry) triggers the "Turn off unified views" preference in the backgrpund (under "document preferences - Legacy 2d features"), but leaving the "Enable legacy 2d feature" unflagged. As a result, a document preference is changed by the software (not by the user), activating legacy features in the background, and has to be manually changed every time by users (again and again...). This also seems related to one more unexpected behaviour: after deleting a design layer, a random sheet layer is activated (see attached video). Is there anyone else experiencing the same issue, which seems to be a bug? We've been able to reproduce this both in VW2023 and VW2024. VW unified views bug v2024.mov 1 1 Quote Link to comment
Steve Barrett Posted October 19, 2023 Share Posted October 19, 2023 I'm seeing this same behavior. 1 Quote Link to comment
Vectorworks, Inc Employee Peter Neufeld. Posted October 21, 2023 Vectorworks, Inc Employee Share Posted October 21, 2023 Hello, You should send this into your local support so they can have a look and report if necessary. I have seen this when an older file has been converted that has some screen plane objects which are inside and part of a symbol's definition. It seems that the Doc Prefs don't detect this and do not turn on Legacy 2D but it can behave as if it is. Cheers, Peter 1 Quote Link to comment
StefanoT Posted October 21, 2023 Author Share Posted October 21, 2023 (edited) Thank you @Peter Neufeld., I’ve submitted it via @Pier Luigi Edited October 21, 2023 by StefanoT 1 Quote Link to comment
StefanoT Posted January 26, 2024 Author Share Posted January 26, 2024 (edited) It seems this Issue is solved with the latest VW 2024 Update 3 Edited January 26, 2024 by StefanoT 1 Quote Link to comment
