Wall textures when upgrading to VW24
b303lmr
1 answer to this question
Hi @b303lmr
I provide Tech Support for the New Zealand market. We've not received any reports of this.
Here's my suggestion to you:
Migrate other files from 2023 that contain walls with textures applied and see if the issue occurs. Ideally such a test would be done using a new blank document (using File > New… > Create blank document, not one of your templates) and use the same texture-with-hatch.
If the problem doesn't occur in the new blank document or in most of your existing 2023 files, the file concerned might have a compromising condition in it. Either a corruption or (most likely) 'far out objects.' To check for these refer to the guide here:
If the problem occurs in the new blank document or all your other 2023 files when opened into 2024, please contact Vectorworks Tech Support for your region.
