bjoerka Posted September 21, 2023 Share Posted September 21, 2023 I have a small rvt file to import (30mb) and vwx24 and 23 crashes after the dialog which shows the revit structure. Is that a known problem? Quote Link to comment
0 Administrator JuanP Posted September 21, 2023 Administrator Share Posted September 21, 2023 @bjoerka Could you share the file for testing and tell us what version or RVT was created? Thanks 1 Quote Link to comment
0 bjoerka Posted September 21, 2023 Author Share Posted September 21, 2023 Hi Juan, i just sent you a message containing the file. Quote Link to comment
0 Administrator JuanP Posted September 21, 2023 Administrator Share Posted September 21, 2023 @bjoerka I was able to replicate the crash in Vectorworks 2023 and 2024. It seems to be an issue with reading the Site Topology data. I have submitted this issue under VB-199444 (Internal database). In the meantime, I suggest you import the Site Topology data as Revit Entity instead of Site Model/Site Modifier. The information will be imported as a mesh-like object, and the import will be successful. I will let you know of any fixes. 1 Quote Link to comment
0 bjoerka Posted September 22, 2023 Author Share Posted September 22, 2023 You are right. I tried to import it as revit file not as Site Model. I even didn´t know what´s inside .-) The files are created with the following version: Autodesk Revit 2021.1.7 Quote Link to comment
bjoerka
4 answers to this question
