Leandrovsk Posted September 12, 2023 Share Posted September 12, 2023 (edited) I'm trying to create a floor (brick in image attached) on the slab, but I can't get the component to line up with the inside of the wall. I've already tried editing the component's "Auto-Bound" option, but none of the options change anything. Or should I make a separate object from the slab, a floor from a polygon? Udate: I think I've figured it out, Bounding can't be manual. Anyway, my question remains, is this the right way to draw the floor or would it be better to create a separate object from the slab? Edited September 12, 2023 by Leandrovsk Quote Link to comment
Tom W. Posted September 12, 2023 Share Posted September 12, 2023 The Edge Offset settings in the Slab Component Settings affect yet-to-be-created Slabs only. To edit the edge offsets of a Slab you've already drawn you need to use the 'Edge Offsets...' button in the OIP. That being said it is often intelligent/necessary to treat your structural floor as one Slab + your floor finish as a second Slab because you're generally running the floor finish between the internal walls + though the doorways + will often have different finishes in different spaces. 1 Quote Link to comment
E|FA Posted September 12, 2023 Share Posted September 12, 2023 Just now, Tom W. said: it is often intelligent/necessary to treat your structural floor as one Slab + your floor finish as a second Slab because you're generally running the floor finish between the internal walls + though the doorways + will often have different finishes in different spaces. My rule of thumb is if I have two or more finishes I model the floor finish separately. If the entire slab has a single finish, I use a slab component. 1 Quote Link to comment
Tom W. Posted September 12, 2023 Share Posted September 12, 2023 3 minutes ago, E|FA said: If the entire slab has a single finish, I use a slab component. But presumably only if the floor finish runs under all the internal walls? 1 Quote Link to comment
E|FA Posted September 12, 2023 Share Posted September 12, 2023 In most cases I don't really care if the extra lines show up in 1/4" sections because my large scale details show the proper assembly and a general notes indicate that the details govern construction, and things look fine in axons/perspectives. 1 Quote Link to comment
