Alignment of a slab floor with an interior wall.
Leandrovsk
I'm trying to create a floor (brick in image attached) on the slab, but I can't get the component to line up with the inside of the wall.
I've already tried editing the component's "Auto-Bound" option, but none of the options change anything.
Or should I make a separate object from the slab, a floor from a polygon?
Udate: I think I've figured it out, Bounding can't be manual. Anyway, my question remains, is this the right way to draw the floor or would it be better to create a separate object from the slab?
Edited by Leandrovsk
The Edge Offset settings in the Slab Component Settings affect yet-to-be-created Slabs only. To edit the edge offsets of a Slab you've already drawn you need to use the 'Edge Offsets...' button in the OIP.
That being said it is often intelligent/necessary to treat your structural floor as one Slab + your floor finish as a second Slab because you're generally running the floor finish between the internal walls + though the doorways + will often have different finishes in different spaces.
My rule of thumb is if I have two or more finishes I model the floor finish separately.  If the entire slab has a single finish, I use a slab component.
