Toggle Floor object color
Ramon PG
3 answers to this question
24 minutes ago, Pat Stanford said:
Class Overrides or Data Visualization in the Viewport.
Data Visualization may work in the Design Layer also.
Class overrides were not working. Data Visualization did the trick easily. The new paradigm confuses a bit, when to use which?
And, thanks for the super fast response.
Edited by Ramon PG
Class Overrides only work for objects that have their attributes set to By Class.
If you are not using Class Attributes then DataViz is your only option.
The other time to use DataViz is if you need to change objects that are in multiple classes so you don't have to use multiple overrides.
And probably 15 other reasons as well. Perhaps others who use them more will make suggestions.
