Steven Morgan Posted August 28, 2023 Share Posted August 28, 2023 File attached, for some reason the colors aren't changing on the 4'6" Stage Deck Height. It was working, sent the file back and forth with someone and then it was broke. Tried resetting all plugins, creating a new viz, even making a separate record that it references and still nothing. Any ideas? DATAVIZ-ISSUE.vwx Quote Link to comment
Pat Stanford Posted August 28, 2023 Share Posted August 28, 2023 I see the problem, but I can't find a solution. But for me, it is not the 4'8" deck that displays wrong, it is the 5'0" deck that displays green instead of Blue. I was about to work around this by using Range instead of Value Infinite to 4'0" 4'0.001" to 4'8" 4'8.001" to 5'0" 5'0.001" to Infinite. Sorry to not have a better solution. Quote Link to comment
Steven Morgan Posted August 28, 2023 Author Share Posted August 28, 2023 No worries thanks Pat, copying out to a new file seems to fix it. I'll put in a bug report. Quote Link to comment
halfcoupler Posted September 11, 2023 Share Posted September 11, 2023 Just an idea: Have you tried to use a text field in the record format, instead of a number field? I guess a number field does not work with 4'6" and 5'0" ,- maybe both are rounded to a value of 5 ? Quote Link to comment
