Christian Fekete Posted August 15, 2023 Share Posted August 15, 2023 How do I setup the dimensions so that I don't end up with fractions of inches like so Quote Link to comment
cberg Posted August 15, 2023 Share Posted August 15, 2023 Unfortunately the units for the Space Tool settings are governed by the VW Document Settings - Units preferences. That means that if you set the rounding precision to the nearest inch, the model will show the same unit preferences in the Object Info Palette. This creates accuracy issues when modeling. Quote Link to comment
BartH Posted August 15, 2023 Share Posted August 15, 2023 You can also edit the Data Tag used in the Space Object, to have units more/less refined than the Doc settings: Bart 2 Quote Link to comment
cberg Posted August 16, 2023 Share Posted August 16, 2023 @BartHays In my file/setup, the Units and Precision settings are grayed out, so I never thought they could be changed. I wonder how the data tags are differently configured. Quote Link to comment
cberg Posted August 16, 2023 Share Posted August 16, 2023 The "Energy Area" parameter does indeed allow adjustment of unit precision. What exactly does that measure? "Room Dimensions" does not, which is also one I would also like to adjust. Quote Link to comment
