  • 1
Soft Goods Rendering
Kevin McAllister
Hello,
I've recently noticed some issues rendering soft goods in shaded rendering mode. Its of concern because drawings now show incorrect information or some soft goods are missing entirely. Here are some examples -
ScreenShot2023-08-04at8_15_08AM.thumb.png.c08d9232f72f7bd7744178e3327e1597.pngScreenShot2023-08-04at8_15_25AM.thumb.png.7affd469591fa29446b7bdf984eb3645.png
Wireframe and Shaded side by side in the design layers. Note some soft goods don't display all the way to the top and ones set to Simple 3D disappear completely.
Similar issues show up in sheet layers. They improve slightly when I dial up the sheet layer resolution but this isn't really a practical solution for file size. I've attached a PDF.
Are others seeing these issues? I most often use the Simple 2D and Simple 3D options when drawing softgoods to indicate goods hung flat without fullness. @C. Andrew Dunning this may also be occuring with your tools.
If others are seeing this too I'll file a bug.
Kevin
Softgoods Section Test.pdf Softgoods Section Test.vwx
Edited by Kevin McAllister
  • Like 2
2 answers to this question
