Letter Sequence
I’m writing a vectorscript, and I need to label multiple objects in a grid (an LED wall to be exact), so my labels would be: A1, A2, A3…, B1, B2, B3… etc.  sequencing numbers is easy, but how do I sequence letters?  Is it possible to convert a letter to a number and sequence that way?
Dave
Easiest way I know of is to use a numeric pointer and then use an offset to convert the number to an ASCII character.
Capital Letter A is ASCII Character 65 Decimal.
So an Integer plus 64 will give you the ASCII code for capital letters
C_H_R_(). will give you the character as a CHAR (single character string). (Remove the underscores. The forum parser would not let me post what I wanted.)
Pat, Thank you as always.  I've always appreciated your help especially when I hit road blocks like this.  I will look for examples of using a number pointer and use of an offset, and let you know if i have any questions.
Did you get a citation from the Forum Police?
Posting government Vectorworks documents or something?
  • 3 weeks later...
