JackMatsedi Posted June 14, 2023 Share Posted June 14, 2023 Why is most of the plants downloaded as SKP or from Vectorworks look flat? see the image below: Quote Link to comment
JackMatsedi Posted June 14, 2023 Author Share Posted June 14, 2023 (edited) Others are fine: Also, how can we edit the overall size of such downloaded objects? On the Object-Info Shape eirther there is no place to edit or there is but uneditable. Edited June 14, 2023 by JackMatsedi additional info Quote Link to comment
JackMatsedi Posted June 14, 2023 Author Share Posted June 14, 2023 Here is an example in the attachment: The W X D X H is 4 and not editable. Quote Link to comment
Tom W. Posted June 14, 2023 Share Posted June 14, 2023 Can you not use the Scale Objects command to resize it? Quote Link to comment
JackMatsedi Posted June 14, 2023 Author Share Posted June 14, 2023 I cannot use the scale command or maybe im using it wrong Quote Link to comment
JackMatsedi Posted June 14, 2023 Author Share Posted June 14, 2023 Is there a video on how to scale? Quote Link to comment
Jeff Prince Posted June 15, 2023 Share Posted June 15, 2023 the first plant looks like a 2D plane, hence the flat appearance. the second plant is an actual 3D model. Quote Link to comment
Tom W. Posted June 15, 2023 Share Posted June 15, 2023 8 hours ago, JackMatsedi said: I cannot use the scale command or maybe im using it wrong Select the Mesh then go to Modify > Scale Objects... Here you can either scale the whole object equally using 'Symmetric' mode e.g. enter '2' if you want to double the size. Or scale it differently in different directions using 'Asymmetric' mode e.g. in Front/Left/Right View enter X Scaling Factor of 1 + Y Scaling Factor of 3 to make the object 3 times taller. Quote Link to comment
JackMatsedi Posted June 15, 2023 Author Share Posted June 15, 2023 Thanks Tom, it really worked to my liking this is what I wanted the whole time. Quote Link to comment
