col clipper Posted May 28, 2023 Share Posted May 28, 2023 Is it possible to constrain symbols in a grid pattern. I would like to be able to produce a generic downlight layout (4 lights symbols in a square) so that I just need to drag the square larger or smaller to suit the room size ? Quote Link to comment
Tom W. Posted May 28, 2023 Share Posted May 28, 2023 You could save the 4 light symbols as a blue Group symbol then when you insert it you can resize the Group to suit the room...? Quote Link to comment
col clipper Posted May 29, 2023 Author Share Posted May 29, 2023 Many thanks Tom... The answer was so simple that I just did not see it ! Now lets progress this a little futher.. I now have a group of light fittings (including interconnectiing wiring) that resizes when I drag the group handles. I would like to add a light switch symbol connected to this group via a constrained 'rubber line or curve ' (to represent wiring). Any ideas how I can create the wiring 'rubber line or curve ' that will resize as I drag the light switch symbol to its position ? Quote Link to comment
Tom W. Posted May 29, 2023 Share Posted May 29, 2023 57 minutes ago, col clipper said: Any ideas how I can create the wiring 'rubber line or curve ' that will resize as I drag the light switch symbol to its position ? How are your scripting skills...? 🙂 See this thread + the example of the Benelux tool: It does seem crazy that there isn't something either within VW or available as a plug-in that does this kind of thing. There is nothing on the Roadmap. I draw up all my electrical layouts manually... Quote Link to comment
shorter Posted May 29, 2023 Share Posted May 29, 2023 Have mentioned the need for this a number of times. It does seem quite a simply thing and essential for the production of small power drawings on smaller projects. Also for the symbol of the switch and light fitting to be both 2D and 3D with definable heights and symbol definition for the 2D and 3D representation. I can see the tool being quite simply in execution. Click to place light. Click to place switch. Or vice-versa. VW draws polyline between the two. Keep clicking if the light switch operates more than one light, etc. Also need to be able to connect symbols after placement as unconnected symbols. I bet there is something similar in Spotlight. Quote Link to comment
