Windoor - Unusual Configuration
I often put multiple WinDoor object together in a single assembly inside of a symbol when a single plug-in can't make what I need.   A common one would be a double door flanked by single fixed doors.  The '2' door setting makes the sidelights double door units, too.  I'll make the entire perimeter out of one Windoor object leaving the sidelights as openings and then place a second and third plug-in into that assembly to make the final product.   There are lots of different configurations where something like this is necessary.
  • 2 weeks later...
On 6/2/2023 at 7:23 AM, SharonP said:
Does anyone know how to do a windoor object that has one door sliding each way like this but not being cavity sliders?  I can't seem to work that one out.
• In the WinDoor OIP, select the dropdown - Window/Door Type: Sliding Left Door or Sliding Right Door
• Then, also in the OIP, select the dropdown - Number of Doors: 4
