Ramon PG Posted March 20, 2023 Share Posted March 20, 2023 My 2023 will not read a 2022 file. It gets stuck forever reading the plug-ins. Ca I make a table with plug-in objects in order to find the objects? Can I update the plug-ins? Quote Link to comment
0 Pat Stanford Posted March 20, 2023 Share Posted March 20, 2023 This sounds like a good file to actually send to Tech Support for their review. If you need it now, try exporting back to VW2021 and then importing that to VW2023. Or just let it run longer on the import. There have been a few cases where there was a delay in the import but it eventually finished when left for a couple of hours. Quote Link to comment
0 Ramon PG Posted March 21, 2023 Author Share Posted March 21, 2023 8 hours ago, Pat Stanford said: This sounds like a good file to actually send to Tech Support for their review. If you need it now, try exporting back to VW2021 and then importing that to VW2023. Or just let it run longer on the import. There have been a few cases where there was a delay in the import but it eventually finished when left for a couple of hours. I'll try your suggestion. Tech already has thad he file for a few weeks, but total silence. Quote Link to comment
0 Ramon PG Posted March 22, 2023 Author Share Posted March 22, 2023 On 3/20/2023 at 1:21 PM, Pat Stanford said: This sounds like a good file to actually send to Tech Support for their review. If you need it now, try exporting back to VW2021 and then importing that to VW2023. Or just let it run longer on the import. There have been a few cases where there was a delay in the import but it eventually finished when left for a couple of hours. I saved to 2021 and tried to open it but same problem, it just hangs there forever and does not translate into 2023. Well, at least an hour. Quote Link to comment
0 Pat Stanford Posted March 22, 2023 Share Posted March 22, 2023 It definitely sounds like there is a problem with that file. Duplicate it and delete different layers from each file and import them separately to try and find the layer with the problem? Or if you have some time send the file to Tech Support and ask them to help you convert it. 1 Quote Link to comment
Ramon PG
4 answers to this question
