JonKoch Posted February 28, 2023 Share Posted February 28, 2023 Hello! I'm trying to get a plant bed to follow the contours of the site model and I'm not sure the best way to do this? A landscape area is set at an elevation so it doesn't seem to follow the terrain. I'd like to show the perennial bed from the contemporary garden landsacpe area to follow the slope. Thank you! Quote Link to comment
Jeff Prince Posted February 28, 2023 Share Posted February 28, 2023 Landscape area set to “texture bed on…(existing or proposed)” will stick it to the site model. You don’t have to set the elevation, landscape areas and plant objects adjust themselves to the model when they are over a site model. Just update the site model to see the change. 1 Quote Link to comment
JonKoch Posted February 28, 2023 Author Share Posted February 28, 2023 1 hour ago, jeff prince said: Landscape area set to “texture bed on…(existing or proposed)” will stick it to the site model. You don’t have to set the elevation, landscape areas and plant objects adjust themselves to the model when they are over a site model. Just update the site model to see the change. Thanks, Jeff! Seems easy enough. Not sure how I didn't pick that one up on my own. Quote Link to comment
JonKoch Posted February 28, 2023 Author Share Posted February 28, 2023 2 hours ago, jeff prince said: Landscape area set to “texture bed on…(existing or proposed)” will stick it to the site model. You don’t have to set the elevation, landscape areas and plant objects adjust themselves to the model when they are over a site model. Just update the site model to see the change. Hi Jeff, Apologies for the confusion, but I tried what you mentioned and i've attached a screenshot of the result that I get. It seems it did place the mulch bed on the model but the landscape area still hovers above. Thanks. Quote Link to comment
JonKoch Posted February 28, 2023 Author Share Posted February 28, 2023 50 minutes ago, JonKoch said: Hi Jeff, Apologies for the confusion, but I tried what you mentioned and i've attached a screenshot of the result that I get. It seems it did place the mulch bed on the model but the landscape area still hovers above. Thanks. Nevermind, Jeff I figured it out! Thanks again! 1 Quote Link to comment
Amanda McDermott Posted March 1, 2023 Share Posted March 1, 2023 16 hours ago, JonKoch said: Nevermind, Jeff I figured it out! Thanks again! What was the answer please, in case we come across the same thing?! Quote Link to comment
JonKoch Posted March 1, 2023 Author Share Posted March 1, 2023 4 hours ago, Amanda McDermott said: What was the answer please, in case we come across the same thing?! When you click on the landscape area, make sure that in the OIP where it says "Site Model Layer" it's on the same layer as the site model and then it should stick right to it. 1 Quote Link to comment
