matteo17 Posted January 6, 2023 Share Posted January 6, 2023 inserting trellis qx30sa to form a ring and verifying the objects on braceworks I get this message what can I do is there any setting I need to change? Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted January 9, 2023 Vectorworks, Inc Employee Share Posted January 9, 2023 Can you post the file? It could be that a connection has been missed. 1 Quote Link to comment
matteo17 Posted January 9, 2023 Author Share Posted January 9, 2023 the problem that tells me structure not connected on braceworks I had 1mm geometric tolerance, maybe it's better to change the tolerance? Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted January 9, 2023 Vectorworks, Inc Employee Share Posted January 9, 2023 @matteo esposito There are a number of things that can cause this but without being able to look at the file it is difficult to say what the actual cause is. If you can DM the file Tom or myself can have a look and figure out what is wrong. Quote Link to comment
matteo17 Posted January 10, 2023 Author Share Posted January 10, 2023 I SEND YOU FILE? Quote Link to comment
matteo17 Posted January 10, 2023 Author Share Posted January 10, 2023 1676007124_poliformmatteo.c.vwx Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted January 10, 2023 Vectorworks, Inc Employee Share Posted January 10, 2023 Hi @matteo esposito I just tried your file and once I had added some hoists it calculates, except for a couple of random sections of truss that are hanging off to the side by themselves. As afar as I can tell all you should need to do is insert the hoists, delete the random truss corner and 3m section that ae not connected to the main structure and you should be good to go. Make sure to use calculate visible or calculate selection rather than calculate all, otherwise Braceworks will try to calculate all the 2D DWG geometry that you have in the background. Let me know if you have any further issues Quote Link to comment
