matteo17
    15
Reputation
0 Neutral
Personal Information
  • Location
    Italy
Recent Profile Visitors
  1. Hi everyone, we have Cyber Hoist or Kinesys hoist in our library
  2. I have to calculate the weight of the exhaust on the leg of the truss (on the floor) to give it to the engineer I attach a picture of the structure vista.pdf
  3. good morning everyone, is there a way to calculate with braces the weight of an American pylon that unloads to the ground?
  4. Hello everyone I'm trying to insert some bridles in a drawing I would like some tips on the settings, height of the hooking points 16.5 meters par basketball stell from 2 m fixed leg of the bridle 4mt leg with 2mt adjustment + 2mt stac chain, apex at 13 m and engine what settings should I enter in the bridle to make everything work properly and find the adjustment of the chain? can someone help me thanks
  5. matteo17
    bridle
    so even if i don't create a stack chian from mt t but i just change the length when i insert it i will get real adjustment ? che i.postazioni devo usare per relolare in modo ottimo il mio bridle ?
  6. matteo17
    bridle
    this is an example I have to insert the bridles to have the regulation of the chain in the construction I can't figure out where I'm wrong in the settings, basket 2m leg with adjustment 2m + 2m chain stack fixed leg 4m apex height 13 m anchorage height 16.5 m provaaa.pdf
  7. matteo17
    bridle
    Hello I have to create a two-way bidle, the beams are 50cmx20cm, 2mt basket, distance between the beams 4m, fixed leg of the bidle 4m steel cable - leg with 2m steel cable adjustment and 2m stack chain, apex height approximately 13.5 m
  8. matteo17
    bridle
    unfortunately I haven't solved it I can't figure out how to create a new stac chain, but when I choose the material from manage bridle parts for the bridle I saw that I can modify the chain from there both length (min and max) and the links
  9. matteo17
    bridle
    good evening everyone I can't use the two-way bridles I feel better in the leg with the adjustment spots the engine point does not move the adjustment of the chain I would like to use 2 m chians with 7 cm rings I am certainly wrong with some settings do you have any advice thank you
  10. matteo17
    bridle
    good evening everyone I would like to understand how to set the bridle settings then I would need to use a 2m long stac chian how can I do it
  11. Hello, is it possible to calculate self-supporting pylons (which are not hung) but discharge to the ground?
  12. the problem that tells me structure not connected on braceworks I had 1mm geometric tolerance, maybe it's better to change the tolerance?
  13. inserting trellis qx30sa to form a ring and verifying the objects on braceworks I get this message what can I do is there any setting I need to change?
