Mid Wall Stucco Colour Transition - Possible in VW ?
dFA
Hi All,
Newbie-ish member here - still on learning curve but enjoying the program very much so far.
Question about best method to transition the exterior surface texture of a wall mid-ht (in this case the only thing changing in assembly is the stucco colour). Is this possible to do in VW ?
Attached is a screen snap from my Sketchup model to show what I am trying to achieve - the upper portion of exterior wall surface is to have a light coloured stucco finish in the same plane as the darker stucco wall surface below.
I am rebuilding the model from scratch in VW23 - would rather not create 2 separate wall types to achieve this visual effect if simpler technique available.
Thanks for any suggestions
dF
Mid Wall Stucco Colour Transition.pdf
