Chris Clymer Posted December 20, 2022 Share Posted December 20, 2022 Hi All, I’m having an issue rotating a roof rafter on the y-axis. Full disclosure, this is my first design using Vectorworks, so I’m still a newbie. I have a shed roof at a 2/12 pitch (9.46 degrees). I have a 2’ roof overhang at eaves and rakes, so I want to show ladder framing at rakes. I’ve drawn the ladder frame rafters, but they’re profile is vertical in the ‘back’ view (see attached). I want to rotate each rafter 9.46 degrees (on the y-axis) so they’re perpendicular to the main rafters at the 2/12 pitch. I’ve tried the rotate command, and I’ve tried rotate 3D, in both “Top/Plan “ view and “Back” view; each time I get a message saying “Hybrid objects can only be rotated about the z-axis”. I’ve done some digging online and others concur that this is an impossibility as objects cannot be rotated in that manner. Surely this cannot be, as ladder framing is a common practice. I’m hoping someone out there can tell me what I’m doing wrong or can point me in a different direction. Thank you! Chris Quote Link to comment
Tom W. Posted December 20, 2022 Share Posted December 20, 2022 What type of object are your ladder frame rafters? If they are hybrid objects then yes you can't rotate them about the X/Y axes because this isn't compatible with their 2D representations. If they are Framing Members for example you need to rotate them using the 'Roll Angle' parameter. If they are hybrid symbols then you need to delete the Top component to convert them into a 3D-only symbol then you can rotate it. Are they hybrid objects as the message suggests? Quote Link to comment
Chris Clymer Posted December 20, 2022 Author Share Posted December 20, 2022 Tom W. - thanks for your response. That's a great question... I'm not sure. I'm using the Framing Member tool under the Detailing tool set, so I assume 'Roll Angle' is what I need. I don't see that parameter under the OIP. Attached, are all that I see available to me. Is 'Roll Angle' located elsewhere? Quote Link to comment
Tom W. Posted December 20, 2022 Share Posted December 20, 2022 If you change 'Type' to 'Solid Beam' instead of 'Rafter' you will get the 'Roll Angle' option. 1 Quote Link to comment
Chris Clymer Posted December 20, 2022 Author Share Posted December 20, 2022 And there it is... Thanks Tom W! Appreciate the help very much! 1 Quote Link to comment
TomKen Posted December 21, 2022 Share Posted December 21, 2022 I was trying to deal with the same issue yesterday. I can have a roll angle for a beam, but as soon as I turn it into an OWSJ I lose that option. I ended drawing the OWSJ joist to the length I wanted with the framing member tool, then converting it to a group so I could rotate it in the vertical plane. If someone has a better way to do this I would really like to hear it. Also I like that they combined all the wall tools into one tool. I wish they would do the same with the Structural member tool and the framing member tool. Quote Link to comment
