Hanna N Posted November 20, 2022 Share Posted November 20, 2022 I would normally do the planting plan in the design layer. This time I will have to do it in sheet layers instead. How do I get the plants in the correct scale? They are massive when placing them in the sheet layer. The viewports in the sheet layer are in scale 1:50 respectively 1:100. Quote Link to comment
Jeff Prince Posted November 20, 2022 Share Posted November 20, 2022 30 minutes ago, Hanna N said: This time I will have to do it in sheet layers instead. why? Wouldn’t it be easier to move your sheet layer stuff to a design layer and do it properly? 1 Quote Link to comment
Pat Stanford Posted November 20, 2022 Share Posted November 20, 2022 Sheet Layers are always at 1:1 scale. If you need to do scaled things on a Sheet Layer, they have to be in a Viewport. Create an empty viewport and put your plants into the Annotation Group. You can set the scale of the Viewport to whatever you need. The Annotation Group will use that same scale. Or as Jeff said, just do it on a Design Layer and use a Viewport to bring it to the Sheet Layer. 2 Quote Link to comment
