Tismacfan. Posted November 18, 2022 Share Posted November 18, 2022 Hello A wall consisting of several components, of which one component is load-bearing. How can I get this component in a different color through data visualization in my drawing based on the load-bearing field value. Tanks for the Info. Pascal Quote Link to comment
Pat Stanford Posted November 19, 2022 Share Posted November 19, 2022 I have not tested in 2022, but in 2023, you can set a criteria of Component Is: Make sure you check the Apply Attributes button at the top left when you set the fill and pen you want the Data Viz to apply. 1 Quote Link to comment
Tobias Kern Posted November 19, 2022 Share Posted November 19, 2022 (edited) Hi, I would try to filter “Materials”. This method would also be handy if you use different materials for different phases. Each “Material” for: new, demolition, … So you can visualize many component phases in just one wall. You can perfectly filter Materials and it works also perfect in Section-Cuts. It should be clear, that the Brick component is load-bearing, only the Brick Component will be colored, but if you want to have the whole wall colored, Pat's solution is working. Greetings from Germany Tobi Edited November 19, 2022 by Tobias Kern Quote Link to comment
Pat Stanford Posted November 19, 2022 Share Posted November 19, 2022 I tried some more last night and I don't think you can do it for the example wall you provided. The Structural Component is a Composite Material. The "fill" is a Tile attached to a Simple Material. I don't think there is a way to change the attributes of a tile using DataViz. Hopefully someone will show us I am wrong and how to do it. 😞 Quote Link to comment
