matteoluigi Posted November 4, 2022 Share Posted November 4, 2022 funny thing, however I don't understand why. first an introduction: There's a symbol in the file with 2 space objects and 2 data stamps inside. Every time I edit the data stamp style all stamps get scaled big and every time I export a pdf with the command "reset all Plugin objects" all data stamps get small again. there's no right or wrong, maybe data stamp objects are not designed for being used inside symbols, I don't know... (reason - all symbol content is in scale 1:1 wether all designlayers have another scale...) now the main part i wrote a little script, which resets all data stamps. however, that script only works when executed from a sheet layer. When I try to run it from a design layer none of the data stamp objects is resetted. WHY? (you can try it in the attached file, if you want) (if you want to get big data stamps again, just edit the data stamp stile...) @Pat Stanford @JBenghiat @odaus !!!! I DON'T WANT NO DATA STAMP; SYMBOL-usage or other help, I JUST WANT TO KNOW WHY THAT SCRIPT ACTS THAT STRANGE WAY I STILL DON'T UNDERSTAND !!!! thanks refresh objects_3.zip Quote Link to comment
matteoluigi Posted November 4, 2022 Author Share Posted November 4, 2022 same behavior in VW 2021 (it's a VW 2021 file) and VW 2023. Didn't test VW 2022, but suppose that there won't be a change. Quote Link to comment
Marionette Maven Marissa Farrell Posted November 4, 2022 Marionette Maven Share Posted November 4, 2022 This appears to have to do with your active layer scale. My best guess is that the script is referencing the layer scale of whatever is active when it runs, since your data tags are set to be a certain way with regards to world-based units, the scaling is layer dependent. This can be tested by changing the active layer scale on your design layer to 1:1 and running the script (then pan or zoom to refresh the screen) The script DOES reset the objects every time it's run, it just appears to have a dependency elsewhere. Quote Link to comment
matteoluigi Posted November 4, 2022 Author Share Posted November 4, 2022 25 minutes ago, Marissa Farrell said: The script DOES reset the objects every time it's run, it just appears to have a dependency elsewhere. so, the way all data stamp objects are been reseted depends on the scale of the actually open layer. Sheetlayers always are 1:1 layers, design layers aren't (1:100 in my case for example) , it's the old scale problem in symbols, which affects that behavior again. Would be great to set up a layer to work like a wanted layer scale, as well. Its about modular building with many instances of a generic floorplan. Obviously that topic is in research... Quote Link to comment
matteoluigi Posted November 4, 2022 Author Share Posted November 4, 2022 yes, just created a design layer with 1:1 layer scale. Resetting data stamps from the 1:1 layer worked fine, as well Quote Link to comment
Marionette Maven Marissa Farrell Posted November 4, 2022 Marionette Maven Share Posted November 4, 2022 The solution to this would be to set the settings of your data tag style to have 'Use world-based units' checked and 'by style' instead of 'by instance'. Quote Link to comment
matteoluigi Posted November 4, 2022 Author Share Posted November 4, 2022 damn it, another VW 2021 issue which is resolved in 2023 and maybe 2022 as well. Maßstabsabhängig should be the word for "use world-based units" (although as far as I understand, it would mean "referred to the scale" which doesn't sound right to me...) however. it seems not to be a scripting problem at all. Quote Link to comment
