James Herrick Posted October 20, 2022 Share Posted October 20, 2022 I am creating 3D model from past Vectorworks projects. I stacked the floor plans, set wall heights, created layers, etc., but when I rotate the model I only get the active layer. Thanks for any help. Quote Link to comment
Kevin Allen Posted October 20, 2022 Share Posted October 20, 2022 In the Navigation palette select "Show. snap. modify others" from the drop down menu Quote Link to comment
Pat Stanford Posted October 20, 2022 Share Posted October 20, 2022 What version of VW? If prior to VW2023, check that you have Unified View selected in the View menu. Also, make sure that all layers are set to the same scale. Quote Link to comment
zoomer Posted October 20, 2022 Share Posted October 20, 2022 Maybe Unified View is off. Quote Link to comment
James Herrick Posted October 20, 2022 Author Share Posted October 20, 2022 I don't see Unified View in the View menu. Quote Link to comment
Pat Stanford Posted October 20, 2022 Share Posted October 20, 2022 Unified view is on by default in VW2023. Please edit your signature to include your VW version and OS so we can easily see what version you are running. Instructions in my signature. If you are NOT on VW2023, and are using a custom workspace, it is possible that it was never added (though it has been around such a long time I can't really imagine that). Try one of the standard workspaces and see if you have Unified View there. Quote Link to comment
zoomer Posted October 20, 2022 Share Posted October 20, 2022 34 minutes ago, Pat Stanford said: Unified view is on by default in VW2023. Definitely. But I am not sure about the previous "ignore layers of other scale" setting which went out of the Unified View Settings in VW 2023. AFAIR I have seen that one time in VW Preferences (or File Preferences) but did not find it later again and AFAIK it was ON by default (*). If it is VW 2023, and it is about a migrated file from a previous VW Version. a) if that File had any "legacy 2D" specific settings like Unified View set OFF (For whatever people needed this) or Screenplane only, in VW 2023 the "2D legacy" Setting in VW 2023 Document Settings will be set to ON automatically, to make the File look as in the previous Version. Which means that you can access the old Unified View Setting from Top Bar. But AFAIK it is not shown automatically anyway. You need to make the Icon Visible from that little Arrow on the right, to show it in your Top Bar for access. b) if a current or migrated File in VW 2023 had no "legacy 2D" settings in it, "2D legacy" setting in Document Settings is OFF and there is no access to legacy things like Screen Plane or Unified View .... In this case you can't even activate the Unified View Icon in Top Bar. It is hidden. You could only access it by activating "2D legacy" features in Document Settings first. (*) Not sure but AFAIK, using different scales for your Layers would cause problems when rotating your View in 3D. Not sure if that default "ignore Layers of different scale" ON is intended or already changed or just came from my file template .... (BTW, who ever wants or needs Layers of different Scale ? For Details ? I personally would not mind if there is only a global Scale for all Layers at a time) Quote Link to comment
James Herrick Posted October 20, 2022 Author Share Posted October 20, 2022 I have used my template for past projects and the 3D models works just great. There must be some glitch in the drawings that I am using to cause the problem. I'll keep looking. Thanks to all of you for the help. Quote Link to comment
Pat Stanford Posted October 20, 2022 Share Posted October 20, 2022 Or post the file and we can take a look for you. Quote Link to comment
