DeadInside Posted October 7, 2022 Share Posted October 7, 2022 I have some Data Insertet into Fixtures but its not showing in a Table I would like to have. https://imgur.com/a/vGETMta Any Solutions? Quote Link to comment
0 Pat Stanford Posted October 7, 2022 Share Posted October 7, 2022 Have you recalculated the worksheet? Are you positive that the row highlighted in the worksheet is the same as the row shown in the OIP? Right Click on the worksheet subrow header and choose Select Item to make sure that the item displayed in the subrow is the one selected in the drawing. 1 Quote Link to comment
0 Vectorworks, Inc Employee jcogdell Posted October 10, 2022 Vectorworks, Inc Employee Share Posted October 10, 2022 @DeadInside Have you customized the lighting device parameter names (in File menu-Document settings-Spotlight preferences-lighting device parameters) or are you using the default parameter names from the German localized version of Spotlight? If you changed the parameter names check that you are using the correct worksheet name for the parameter, as this can't be changed. If you are using the default German parameter names and haven't changed anything please contact tech support at Computerworks, the German distributor, they will be able to help figure out what is wrong Quote Link to comment
DeadInside
Any Solutions?
2 answers to this question
