Shortnort
198 -
Everything posted by Shortnort
AHHHH - the old double click scenario. I was only single clicking. Thanks...
I am also pulling my hair out with stair 2d visibilities. I have a 3 story building. For some reason the visibilities don't want to cooperate and this is critical... I have a room under a stair so I do not want the dashed lines above, so I turn visibility off. However, that then is inherited by the floor above but I want to see the dashes there... I guess automating this isn't worth the headache - I will turn off and simply draw the dahed lines where appropriate. Another thing I am scratching my head over is materials for the 3d stair componenst... I can not find where they can be defined by material.
In VW2022 I can not find where the door hardware class is set... Where is it hiding?
how to create an the Occupancy type and Code table with the Space tool
Shortnort replied to Matt Hall's topic in Architecture
Thanks, Wes. More than likely I will not be able to accomplish this in 2020. When I went into the Define Tag Field, a bunch of gobble-d-goop displayed and without saving, the display showed the same gooble-d-goop. I have been trying desparately to upgrade to Windows 10, but have had ZERO luck. An unknown error keeps popping up. I have researched many sites, done exactly what they suggested, and of course, still no luck. I have tried downloading the iso file, but when the file is almost completed downloaded, I get a disk fail error saying the disk is too small, yet the 32G flash drive isn't large enough for a 3.5G file... Go figure. Guess I am stuck in VW2020 for yet a while longer. Thank you so much for your help. Here is a screen shot of the Define Tag Field: -
Thanks, Wes. More than likely I will not be able to accomplish this in 2020. When I went into the Define Tag Field, a bunch of gobble-d-goop displayed and without saving, the display showed the same gooble-d-goop. I have been trying desparately to upgrade to Windows 10, but have had ZERO luck. An unknown error keeps popping up. I have researched many sites, done exactly what they suggested, and of course, still no luck. I have tried downloading the iso file, but when the file is almost completed downloaded, I get a disk fail error saying the disk is too small, yet the 32G flash drive isn't large enough for a 3.5G file... Go figure. Guess I am stuck in VW2020 for yet a while longer. Thank you so much for your help. -
Wes: I use version 202o since I am still in Windows7 platform. Is your example available in version 2020? If not, any advice on how I should upgrade to windows 10? I am a bit skittixh about doing that. -
Spaces - How to add Occupant Loads to Labels?
Shortnort replied to Shortnort's topic in Architecture
Oh, well... It would be great if there was a way to have a numeric Additional Information field to allow this. I am sure that most architects would love to have this feature incorporated into the Space Labels. Thanks for the suggestions!!!!! -
Oh, well... It would be great if there was a way to have a numeric Additional Information field to allow this. I am sure that most architects would love to have this feature incorporated into the Space Labels. -
How do you add Occupant tabulations to the Space Labels? I do not see a way to do the actual calculations. I want to display the SF, SF per occupant, and Total Occupant Load. The first 2 I have already.
Is there a link to a video on creating door hardware sets? I have created door types with specific door hardware set numbers, but occassionally I need to change some door hardware items, so the hardware set assigned is no longer applicable. The door schedule will not allow me to modify the hardware set. So - is there a way or must I creat a new door type just for this minor change? I am really surprised at the very limited info available on door hardware. Any links or suggestions are welcome.
Another wierd thing is now happening... I can not split the wall. When I split the wall, the opening I had at the end of the wall whifts to the wall cut location. Strange.
A couple of things wierd this morning... 1. When I went to copy a CMU wall the original wall disappeared. Is there a setting that I have accidentally changed? 2. I ended up having to draw a new CMU wall. When I did a Wall Join with the new wall, the original wall disappeared... WTH?
Curtain Wall insertion into CMU wall problem
Shortnort replied to Shortnort's question in Troubleshooting
Great!!! Thank you. I thought I had done that before, but I guess Not. Dennis -
For some reason when I insert a Curtain Wall into a CMU wall, the CW doesn't punch into the wall. The wall clips to it... Any suggestions on fixing this? I have never encountered this before, so it must be some setting somewhere that I am not aware of.
Has anyone come up with a simple solution for breaking out the data needed for performing a Comcheck analysis? I am currently going to elevations viewports and creating geometry for windows, doors, etc and hand entering the SF of each - very time consuming. Is there a way to utilize spaces for this? Or another way? Any suggestion is appreciated.
Wall Cleanup - How to extend finishes to other than wall style
Thank you. The problem arises in the fact that the CMU has no finishes - just a bare CMU wall, thus no wrap is possible for the CMU. I will try end wrapping the stud wall that abuts the CMU wall and see if I can get it to cover exposed CMU. Thank you for the assist. -
More than likely the issue is v2020. I need to update windows so that I can get the latest versions. Anysuggestion on process of upgrading? -
I could not get it to work... -
Great!!! Thanks. -
Is there a way to extend materials in a wall style? I have used the wrap tool, which works great, but I have a situation where a metal stud wall abuts a CMU wall and I need for the drywall to cover the face os the CMU... I have tried component trim, etc., but can't seem to find a way to accomplish this.
General notes cannot be placed in drawing more than one a ta time?
Shortnort replied to Ramon PG's question in Troubleshooting
I TOTALLY AGREE!!! I thought it was only me that was having this problem. IMO it is worthless. I just creat a spreadsheet and reuse/modify per job.- 1 reply
- 1
Worksheet Help - formulas for Occupancy Loads
Shortnort replied to Shortnort's topic in General Discussion
Thanks, rDesign!!! Unfortunately, I am running 2020 because I am using Windows7... Guess I need to upgrade, but am very nervous about it... The last time I upgraded from XP to 7, it was disastrous - many programs did not work, lost files, etc..... Any suggestions? So..... it seems to be so basic, yet so complex, to get rid of the error... Do you know of a formula/function that can read the numerator and if 0 display a value for the formula as 0?
