Archistyles
57 -
Reputation
11 GoodPersonal Information
Location
Canada
Recent Profile Visitors
2,721 profile views
Hi @JuanP any update on the Vectorworks / Snapdragon X Windows compatibility? thx
Thank you Tom I will check it out.
Super 👍 VW 2025 is good thx
Thanks Tom The project is a small house , so I think I this symbol insertion in wall method should work, however I have never done and would like to learn. Do you mind sharing the Vectorworks file of your example? that will be big help . cheers
Hello Any idea how to deal with tapered wall components? I need to show ICF wall with tapered conc. & insulation at the top Please see attached example thx ICF-with-double-taper-top-to-wood-framing-and-siding-pdf.pdf
Vectorworks Architect 2024 for Sale
Archistyles replied to Archistyles's topic in Buying and Selling Vectorworks Licenses
Sold. -
How to show hatch/fill on stair treads with hidden line rendering
Archistyles replied to Archistyles's question in Troubleshooting
It does work indeed!!!! I guess we can't rely on surface hatch when it comes to stairs and use rather stairs 2D classes attributes. Many thanks for the tip. -
Yes , turning 2D components off make other info disappear : doors will not show in open position , stair 2D graphics (walk line, number of risers, ..) I created a partial viewport for the stair only with 2d components unchecked and superimposed it on the full plan viewport and it seems to give some ok results , below screen shot. It doesn't feel this is how it should be dealt with , I think Vectorworks should make the stair object itself display the info in same manner as the floor object. Re: 2D classes for the stair I need to turn off, I didn't set any. do I need to in this case? Thanks for your help -
Thanks Tom I think my setup is correct : Top view , hidden line I took a screenshot of the viewport with the OIP. I have a steel platform ( floor object) with the same texture as the stair on the same plan/viewport and it shows the surface hatch. it seems the stair object has a different behavior ? or I am missing something? I am on 2024 Architect -
Archistyles posted a question in Troubleshooting
Hi everyone I have a steel stair to which I assigned a perforated metal texture with associated surface hatch to the treads. -Shaded render OK -I have an issue with hidden line render. First , surface hatch associated with the texture wouldn't show in hidden line render , so I had to assign it as fill in the attribute tread top face in the stair setting. however the hatch shows only in hidden line render view from design layer and not from the viewport. Is there a setting somewhere to fix it? Thx -
Vectorworks Architect 2024 still available if anyone interested. $2,500 CAD -
Door Transom alignment
Archistyles replied to Amelia S's question in Wishlist - Feature and Content Requests
Hi there As a follow up on the discussion in yesterday's open house with @Neil Barman & @Matt Panzer , I am attaching a sample file to discuss further what I think Vectorworks is lacking : window-wall tool ( note : window-wall & Curtain-wall are 2 different systems in real life). This window-wall system are widely used in high-rise residential as a cladding system , in combination with other claddings ( precast, brick, metal..) 1- span from floor to floor with ability to extend below slab at soffit condition. 2-slabs (which support the system) cut-in into the system and typically metal panel form the outside finish ( could be spandrel glass as well) 3-louvres / metal / spandrel glass panels at top (horizontally , under the slab) 4-sliding doors at balconies 5-Awning windows 6-Metal / spandrel glass panels , vertical floor to ceiling , to conceal interior walls/structure. 7-Studs / insulation / drywall behind the metal / spandrel glass panels. 8-Report the window-wall system in a window schedule In the attached example , there is a bitmap of the result sought after. The indoor tool was getting some results , not ideal. There was alot of modelling involved for metal panel cover at slab , drywall partition at back-pan locations... with obviously is not working especially , those modelled parts (not part of the window-wall ) won't report in the window schedule It seems to me with there are a lot of limitations with what Vectorworks has to offer. I would like to hear if anyone has an idea how to proceed with this type of exterior wall modelling Cheers Sample Window Wall.pdf Sample Window Wall.vwx
Wall closure and wall direction not responding properly
Thanks @Tom W. & @Matt Panzer The issue with round closure is the radius . it is greater than the door/window distance from the outer edge of the wall. And thanks for clarifying the wall direction confusion.
